1989 560SL turn indicator flasher location
Old Oct 19, 2007 | 01:46 PM
exsailor66's Avatar
Default 1989 560SL turn indicator flasher location
I'm new to MBs, and have an immediate problem that is probably basic, but I don't have a manual yet.
Myturn indicators stopped working yesterday, and I've checked and verified the fuses. If this car is anything like others, and I've discovered that it isn't, it has a flasher device somewhere. I don't know where it is located or what it looks like. Can anyone please enlighten me? People look at me strangely when I use hand signals, andI get horns honked at me, but, most of all, it is scary.
Cheers,
Mike
Old Nov 19, 2007 | 04:10 PM
bluesl560's Avatar
Default RE: 1989 560SL turn indicator flasher location
Hi Mike, I had the same problem with my '86 560SL. I took it to my mechanic and he fixed it by replacing the emergency flasher switch in the center console. Have you checked your Emergency flashers? I know it's been a month since your post with no replys, so you may have already worked this out. Just thought I would chime in and share my recent discovery.
Good luck, BlueSL560
Old Feb 27, 2008 | 09:15 PM
T Bone's Avatar
Hi Mike,
I had the same stuation and sure enough, it was the emergency flasher. I did not replace it, I just pulled the wires away from each other and coated the bare wire that had been chaffed. No problems since.
Tony
Old Jul 23, 2015 | 06:36 PM
ronjohnstone's Avatar
Default Flasher location, 560SL
The actual flasher relay on my '86 560SL was finally found kind of to the left of the speedometer. If you remove the LF speaker, you can - assuming small hands, reach in palm down and you will find a relay a bit larger than 1" square and about 2" high. If you operate the turn signals, you will find that you can feel it "clicks" as it makes/breaks contact. If it does, it is operating so leave it alone. If you have to get it out, pull straight up and be SURE to note its orientation so you can get it back in as it will be a bear to do anyway as there is just no room and you can't see it. If you forget to note it, the two contacts go to the right and the single to the left.
If you have large hands, forget it as there is no room and it's sharp getting in there.
Old Jul 25, 2015 | 06:03 AM
dreamer no2's Avatar
This is the location of the flasher relay . Try pressing the hazard flasher switch see if it is not stuck in the middle possition it can be the problem To find the relay awitch it on, and listen .. The picture is showing with kick panel and knee bolster removed ..
Old Sep 2, 2019 | 10:25 PM
Samuel Harris's Avatar
Really need more detail info about how to get out the relay plz If you could message me my number is 503-400-8735 my name is samuel need assistance as much as you can and very soon please! Thank you!
Kgreer
Dec 17, 2008 12:08 AM
edwardlockett
Oct 14, 2008 09:47 AM
ras716
May 3, 2008 06:22 AM
ras716
May 3, 2008 06:02 AM
magicmarker3927
Apr 15, 2008 09:03 PM
