1979 450sl Power Window Problem
Old Jul 14, 2014 | 02:28 PM
autobuff's Avatar
Default 1979 450sl Power Window Problem
Recent purchase... windows worked... then stopped working.
Switches good, both window motors good but no electric at #3 or 4 fuse.
Is there an electric terminal or block I can check? Any input would be appreciated. Thank you.
Old Jul 27, 2014 | 08:20 PM
autobuff's Avatar
Default power windows
OK found the problem. Had to do with changing the RS taillight assembly.
Window circuit is on Brake light and when I replaced it I apparently crushed the wires causing the connections in the taillight to become loose.
I cut away the heavy plastic insulator which allowed the group of wires to fit in the plastic opening properly. OK now.
oldskool
Apr 2, 2009 11:37 PM
Georgiapeach
Mar 4, 2008 02:13 PM
sjett
Sep 23, 2005 03:51 PM
sjett
Sep 23, 2005 03:49 PM
smbrat
May 2, 2005 08:51 PM
