06 560SL auxiliary water pump.
I am going to replace the auxiliary water pump that it leaking. I might have caused it to leak. The mono-valve doesn't work , have rebuild but still no good. I replace it with an old car hot water heater shut off. I can shut off in summer and adjust water flow in winter. Does this pump run all the time. If so I might have ruin it when I should off the hot water valve in the summer. Would it be best to unplug the juice to the pump in summer when the hot water valve is closed.
Hello - did you mean to put 86' 560SL? What platform is this in regards to?
Should have been 87 560SL
Should have been 1987 Mercedes 560SL Sorry about that
No worries at all, thanks for clarifying. Take a look at the link below to a DIY tech article from our site with the procedure. Hope this helps you a bit and best of luck!
Mercedes-Benz R107 Water Pump Replacement | 1972-1986 - 450SL, 380SL, 500SL, 560SL | Pelican Parts DIY Maintenance Article |
87 560SL auxiliary water pump
I'm talking about auxiliary water pump not water pump up front.
