03 SL 500 REAR AIR SUSPENSIONS TOO HIGH
RE: 03 SL 500 REAR AIR SUSPENSIONS TOO HIGH
THANK YOU SLEEPWALKER! I WILL DO THAT. SLEEPWALKER, YOU THINK THE REAR SENSORS MAY BE DEFECTIVE. CUZ WHEN I START THE CAR, ABOUT 3 SECONDS LATER THE SUSPENSION JUST PUMP UP WITH VIBRATION HIGH BY ITSELFNOT NORMAL AT RISING LIKE IT USED TO....I WILL CHECK AND LET YOU KNOW HOW THINGS GOES. THANK YOU AGAIN!
THANK YOU VERY MUCH SLEEPWALKER. I CHECKED THE REAR SENSORS AND FOUND IT CORRODED. I TRY AND REPLACED IT. NOW THE CAR GO BACK TO ITS NORMAL HEIGHTS. THANK YOU AGAIN.......
SMOOTHRIDE.:}
SMOOTHRIDE.:}
carid
04-07-2015 08:45 AM
