What is a good High Speed Tire in 15" ?
hi guys.,
I am looking for a good high speed tire in a 15".
when I say high speed., i mean cruising at 140 or 150mph.
i live in the desert and i can cruise high speed often.
i currently have some Pirelli Cinturato 3000's.. I think they are only rated at about 112Mph.
thanks,
Kevin
thanks,
Kevin
It's more important to get the appropriate speed rating as opposed to a particular brand.
V = 149 mph
W = 168 mph
Y = 186 mph
Z = >149 mph (it's never been clear what this means,i.e., what's the top limit?)
Speed ratings apply only to brand new tires that are properly inflated and have never been damaged or repaired. You increase the risk of tire failure the longer you drive at these speeds.
V = 149 mph
W = 168 mph
Y = 186 mph
You can find road condition for those speeds in Mercedes in several states.
What I would start with is checking the car governor.
I have V-rated tires on the car with governor set at 125 MPH.
Should that make sense?
The speed governor is different by car models and car manufacturers. There's no standard as far as I know. The designers must determine the top speed using all the appropriate variables such as tires, suspension, engine power, politics, etc, etc.
ORIGINAL: Lugnut
The designers must determine the top speed using all the appropriate variables such as tires, suspension, engine power, politics,.
From what I was able to check, sport cars have 125 MPH, our ML is 115, friends GMC van 100.
