W126 Heater Matrix Leak
Old Aug 30, 2004 | 07:12 PM
matsmith's Avatar
Default W126 Heater Matrix Leak
My matrix is leaking. It's not pouring out but enough to need to carry some water.
Has anyone replaced their matrix, is it a nightmare of a job??
Has anyone tried bypassing the matrix and having no heat.
Has anyone had any success with chemical sealents in the cooling system ?
Any help is appreciated.
Old Aug 30, 2004 | 07:55 PM
C280 wizard's Avatar
Default RE: W126 Heater Matrix Leak
I hate to seem stupid, but what is a heater "matrix" I know what the word matrix means, but never applied to a heater, are you talking about he heater core?
Old Aug 30, 2004 | 11:01 PM
sleepwalker's Avatar
i saw that movie.
Old Aug 31, 2004 | 10:37 AM
So did I, Twice in fact, but if you are referring to the core, it is probably under the dash.
Old Aug 31, 2004 | 11:36 AM
oh, the heating core i see
i think the hot water is coming from the engine, and therefore must have a hose somewhere on the engine firewall. how about plugging it with something.
i live in a hot country and it's very common to see it. ( i didn't reccomend that)
Old Aug 31, 2004 | 04:20 PM
cmscott16's Avatar
Chemical sealants NEVER work for heater core problems. Is what they will do at best is provide a very temporary fix, at which time the problem will resurface and you will feel like a complete idiot for spending so much time and money on chemicals that just give you more problems.
There should be 2 plastic, (possibly metal) fittings protruding from your firewall which are connected to the heater core. They will be connected to hoses, and you will know they are connected to the heater core becasue the fittings will most likely be different than the rest of the cooling system. (Be careful not to break of snap these, as then you WILL need to replace the heater core.) Check to make sure the fluid is not just leaking from a hose. If it is, patch it up or replace the hose. If the leak is from the heater core itself, you will know by turning on the heater. A faulty heater core will emit antifreeze fumes out the heater vents and your windshield will fog up with a film when it's cold outside. If this is the case, you have a bad heater core and it will probably not be the most enjoyable experience to replace. If you want to plug it or bypass it you shouldn't have any problems. If there is enough room, just remove one of the hoses, and then connect the existing hose to the fitting on the engine where you removed the first hose from.
Old Aug 31, 2004 | 05:26 PM
matsmith's Avatar
In the UK the core is the matrix. sorry for the confusion. I am getting steam on side of the screen and water is leaking into the rear vent between the two front seats, with dampness in the rear footwell. I think the core has gone. My dilemma is the car is not worth much and the garage has quoted more than the car cost me. I don't want take the dash out and end up making it a real mess with nothing working anymore when I could just bypass the core and just have cool air!!
Is replacing the core a job for a novice? Has anyone tried it?
Does the whole dash need to come out or just the console??
cjscos
Nov 21, 2008 01:50 PM
unimogman
Nov 11, 2008 09:40 PM
anhhuy88
May 4, 2007 02:24 PM
Vstylez
Jul 17, 2006 09:55 PM
Vstylez
Jul 6, 2006 12:00 AM
