S320 - UK Limp Mode
Old May 21, 2007 | 07:40 AM
nkotecha's Avatar
Default S320 - UK Limp Mode
Hi Forum
Need soem advice - think of buying a S320 UK Spec car - it is very cheap - HOWEVER the reason for this cheapness is that there is a fault with the car - and that it is in Limp Mode - the owner tell me that he had it checked out and it is the ESP module - now I have no means of checking this
This car is approx 4000$ - with 88K and a host of extras - so do not want to let it go - however I do not wanto to buy a money pit
Can anyone shed soem light for me - Also - if I shoudl stay away from this tempting deal - or go for it and hope for the best
The history is - that the car was fine - until it went into the body shop for a spray - no panels were removed - but when he came to collect it - this fault has occured - mayeb a battery problem? - ESP - wiring?
HELP
Nik
Old May 22, 2007 | 01:43 AM
snanceki's Avatar
Default RE: S320 - UK Limp Mode
The call is yours!
Unless you have confidence in the seller I wouldn't buy a wild card unless you are prepared for some serious spend.
How much history can the seller give you. How long did they have the car. Can you contact the previous owneretc?
All faults can be put right (except for body damage) but at MB OE prices you MAY need deep pockets.
If however it is a project and you intend to go around breakers yards etc for parts and solve each issue in turn without requiring the car as daily transport then it may be an interesting, rewarding and possibly profitable undertaking.
Be warned MB bits are expensive and access to body electric codes etc can't be done with a regular DIY scanner.
Thats why the vehicle is going so cheaply!
Is it just the ESP? or a load of other things. If its just the ESP then this shouldn't be too much of a challenge but the ESP links to many other systems.
ASR, ABS, BAS, Airmatic etc.
But of course it could be something real simple.
Stuart
Old May 22, 2007 | 02:05 AM
nkotecha's Avatar
Well - I bought the car - fingers crossed
I went there - when I started the car - I got the messages on the dash ESP Visit Workshop/BAS Visiit workshop and the car was surging when started first - then settled -
I looked at the battery in the boot - and it was small (looks like a cheapo one)
Anyway - i negotiated him down to £2500 - I will give it a go - otherwise off she goes on Ebay!!!! or Break!!
But again woudl liek some feedback on if anyone has had this issues - and where should I start first!
Thanks will keep you guys posted - SLEEPWALKER - please give me your godly blessing!!!!
Nik (UK)
Old May 22, 2007 | 02:16 AM
sleepwalker's Avatar
if the battery was disconnected, it can be as simple as initializing the steering angle sensor.
cmarksmith
Apr 28, 2009 05:33 PM
Duffman
May 8, 2007 06:16 AM
addys
Jun 23, 2005 12:09 AM
Razman
Jul 21, 2004 05:28 AM
briankfaucher
Mar 19, 2004 02:18 AM
