S320 (1994) Indicators Don't Work
Hi, I have a 1994 Mercedes S320 however, I am having a few electrical issues. I am starting with the Indicators, the Hazards work perfectly fine but the left/right signaling function does not work. I was hoping to fix it myself but I don't know even how to remove the steering collum cover.
Can anywone advise what the problem might be or even how to remove the steering wheel collum cover.
Garrett
Garrett
if your not even capable of taking out the steering wheel, I suggest don't do it your self, send it to a certified mechanic, the airbag incorporated on the steering wheel can blow up on you and cause injuries if your not knowledgeable.
the signal switch and the replays of your signal lights may be the culprit. either get a manual to give you a step by step for safety precaution or spend a small amount for safety sake. I assure you by doing it yourself with absolutely no knowledge is like saying curiosity kills the cat. Good Luck.
bright rider
09-12-2008 02:03 PM
