S280 PROBLEM STARTING
Old Oct 23, 2007 | 02:16 PM
mercmad's Avatar
Default S280 PROBLEM STARTING
hi all,
i own s280 and its started to give problems the problem i am having is when you insert the key and turn it, itfails to do anything, for example the starter motor dosent turn over, when i turn off the ignition and turnit on couple it times then it will start after few attempts.
what could this be, ignition system?
Old Oct 23, 2007 | 05:24 PM
waffler's Avatar
Default RE: S280 PROBLEM STARTING
Sounds like a loose connection on the switch
Old Oct 24, 2007 | 12:22 AM
snanceki's Avatar
w140 or w220?
Get the car On Board Diagnostics scanned using MB Star Quick Check diagnostics.(at an MB dealer). Small charge that will save you a lot of money potentially. The body CAN needs to be accessed and this cannot be done by many garages.
Likely the Electronic Ignition Switch EIS is the problem but these parts are expensive and you do not want to change parts unless confirmed by the scan.
Old Oct 24, 2007 | 10:16 AM
syedabdulshahid's Avatar
Check the connection at the starter motor solenoid.Sometime the connections
need to be cleaned.
Syed
Old Oct 24, 2007 | 03:03 PM
NAZ's Avatar
NAZ
if its model chassis W220 it will be the starter relay which is found on right side fuse box,its a odd one and its green relay........
Old Oct 28, 2007 | 11:38 AM
mercmad's Avatar
hi guys quick update, i had the starter relay replaced, as the star program said it was faulty, iy was replaced month ago, so it cant be the relay as it was replaced, the other thing i have noticed is when you open the car a message is displayed switch off the lights but all my lights are switched off.
Old Oct 29, 2007 | 02:07 AM
snanceki's Avatar
I suspect a problem on the CAN. Water / corrosion / or some other faulty unit eg. lighting switch. etc etc.
This will show up on a MB Star Diagnostics check rather than a straightforward OBDII scan.
When it was checked previously were there any other codes present or just the starter relay code? Did the new starter relay (temporarily) overcome the problem or not?
Need a better description of the history of this problem to help any further,
Mileage? w220?
Stuart
Old Oct 30, 2007 | 03:30 PM
mercmad's Avatar
when it was on MB star diagnostics it just showed the green relay which is the starter relay, and had it replaced you were correct in sayin it was temporarily fixed, this morning the car still wouldnt start, i opened the fuse cover and started to push the relays in just in case they were not sitting in, i tried to start the car and it started, i noticed that there was a black relay next to starter relay i touched it while the car was on, and the engine turned off, i got a new relay at the cost of £30 and replaced it in the fuse box, and everything seems to be fine now, i`ve used the car several times today and seems to be fine.
Old Oct 31, 2007 | 01:04 AM
  #9
snanceki's Avatar
Looks like you have located the problem. However it may not be the second relay you have changed BUT the wires to the starter relay below the plastic surface into which they plug.
Suggest you run the car till you get a reoccurrence and if not then all is OK. If you do get a reoccurrence of the problem investigate the wiring below the plastic deck to ensure the connectors have not corroded.
Stuart.
Old Jul 18, 2011 | 03:11 AM
  #10
naadiyaali's Avatar
Default S280 doesn't start
Hi there
I have an S280 1996, it doesn't start anymore.
it cranks just fails to fire as no spark in the coils. I have tried alot of places, installed all new spark plugs, new battery, alot of fuel, got mercedes Coutts to give diagnostics-no luck still.
it just stopped working after a fuel leak which was fixed respectively but it fails to start and for diagnostics the ignition module,cam and crank angle sensors were also checked and tried donor parts. there were 2 alarms -1 factory alarm and a second mongoose alarm, some after market wiring by previous owner, the TV and sound system works but the car doesn't start . My car has not been working since march 2010, any suggestions?
Looking forward to any reply
benzmerc
Apr 30, 2015 09:33 PM
Auto iQ
Aug 15, 2008 04:08 AM
irideforlife11
Nov 20, 2007 08:17 PM
lorkmiester
May 21, 2005 08:55 PM
amrit
Aug 15, 2004 11:36 AM
