S class battery
S class battery
I'm about to change the battery in my 2001 S430. What memories will I lose when I disconnect it? A local parts supplier sells a cigarette lighter plug in device that runs on a 9 volt battery and is supposed to save all memories. Will this work or is it even necessary?
Mark
Mark
RE: S class battery
memory that might be lost: power window, radio station, sunroof, steering angle sensor, and clock.
RE: S class battery
As Sleepwalker but DO NOT apply any load eg Interior lights, ignition, boot light etc otherwide the memory will still be lost since the drain will be greater than the capacity of the dry cell.
Can you PM me the URL for this device.
Stuart
Stuart
RE: S class battery
The plug into the cigarette lighter wont work on a MB if the ignition is off. If you turn it on the current draw from the stuff will be excessive. A trickle charger clipped on the cables might do the job. Other than that just re-sync the windows and radio, clock, steering angle sensor will reset if you turn the wheels end to end, I dont think the seats will be affected.
RE: S class battery
You know what else u can do? take that 9volt and attach wire leads to it then attach them to the battery posts and then remove the battery. Problem sloved with no charger, or anything else in the way.
RE: S class battery
Thanks for the advice on the battery disconnect. Does anyone know of another device that is used in shops when disconnecting? I know of a mechanic who worked in a Sears service cneter for years. Sears must have something that they use on a daily basis. I'll try to contact him for their answer.
Mark
Mark
