No power to Drivers Side door - HELP
All of my drivers side controls on 2000 S430, such as power windows, power mirrors, seat adjustments, everything, has stopped working and does not appear to have any power!!! I checked fuses and don't think it is any of the f## fuses ..... does anyone have any idea where to look (fuses again, or ???)
There are no lights or any indication of power to anything on drivers side, EXCEPT door still locks/unlocks with remote. Passenger side everything works and lights up.
Any help would be greatly appreciated by newbie [sm=americanasmiley.gif]
RE: No power to Drivers Side door - HELP
you need to replace the driver door control module, also know as the seat switch everything runs to that switch. i had the same problem with the pass. side. no pass window, no seat movement. changed the switch and everything works. i have the switch you need. give me your p/n and ill sell it to you if interested
#9
Same problem here.
Hello idk if you had gotten that fix. But I have the same problem. My clk320 has no power to the door, but mine is caused by a short or ground. But you may want to check your prefuse box. It will be large fuse #1. The prefuse box is located in engine in front of your battery. It’s the black plastic box that has a red + to where you jump your Mercedes Benz. But I wish you luck on that and hopefully yours isn’t a short or ground like mine.
