Ignition
Old Oct 24, 2006 | 02:29 PM
Michalplo's Avatar
Default Ignition
I have a 2001 s430. Recently when I start the car it takes two cranks to do so. Its weird... the second time it always starts. Does any one have an idea why?
Thank you
[&o]
Old Oct 24, 2006 | 08:11 PM
AMGMercedes's Avatar
Default RE: Ignition
Cold weather? Where are you located?
Old Oct 25, 2006 | 12:33 AM
Michalplo's Avatar
Voorhees NJ, You think thats whay?
Old Oct 25, 2006 | 10:37 PM
azndude2166's Avatar
might wanna check the spark plugs and what not... might wanna have someone check the ignition, could be a bad spark or something. im not sure bout that part of NJ but if its THAT cold i guess its possible. if u have garage, is it the same in there? or in an enclosed area?
Old Oct 26, 2006 | 02:00 AM
vovpar's Avatar
get the car scanned, since its always starting the second time, it means that something is not adjusted correctly, so it adjusts itself by your ECU and always starts the second time
Old Oct 26, 2006 | 02:25 AM
vytamenc's Avatar
get yourself a cam shaft position sensor. not a crank shaft position sensor. it is located on the front of the right cylinder head they cost about 80 bucks. is what this sensor does is temm the m.e. control unit when the motor is at tdc and the m.e. control unit will fire cylinder number one and the correct time
Old Oct 26, 2006 | 04:59 PM
Michalplo's Avatar
Thanks, i will get it scann... Hopefully its nothing major.
Myran
Dec 6, 2018 03:17 PM
71280sl
Oct 4, 2010 11:38 AM
brantchastain
Oct 2, 2010 06:17 PM
downtown
May 20, 2004 03:24 AM
nineknot
Apr 19, 2004 04:17 PM
