gas cap / check engine light
I have had this happen before :
warning light comes on and says gas cap loose ,,ok I fix it and goes away and then sometimes the check engines light follows ,,and again it goes out ,,HHHmmm!! this time its been 3 days and the light id not going out ?????
and ideas on what I need to do???
thank you
Rick
2000 S430
88k on her
thank you
Rick
2000 S430
88k on her
RE: gas cap / check engine light
Get the DTC Diagnostic trouble Codes read (and make a record of them) in the Engine Management System and RESET the CEL Check Engine light.
Sometimes the light may not return. It COULD save a repeat trip to the garage..
Any garage with an OBDII scanner should be able to do this.
This will give an indication of the problem.
Stuart
Stuart
Stuart,
thank you , but I am alittle new at this ,,how do I get the DTC Diagnostic trouble Codes , in the Engine Management ? is this with a tool or is it something I have access thru something my car had that I do not know about ??
thank you Rick
thank you Rick
You need an OBDII compliant scanner. You can buy these on eBay/auto shops etc but an alternative is to get them read at your local garage (may be chargeable. 2 minute job).
Stuart
Stuart
Kikoap
07-30-2012 02:50 PM
Kikoap
03-27-2012 10:37 PM
