Fuel Problem
Old Mar 11, 2007 | 11:56 AM
Puck's Avatar
Default Fuel Problem
I recently acquired a '94 S500 w\ a 5.0 ltr. engine and it has developed a bit of a problem. After running the car there is a strong smell of gas that appears to be coming from around the filler tube. There are no puddles of gas on the ground to indicate a leak and there are no fumes in the cabin area, or under the hood from what I could tell, so I'm at a loss. Any suggestions? THANKS!!!
Old Mar 11, 2007 | 01:40 PM
chassis221's Avatar
Default RE: Fuel Problem
Possible lines at fuel filter are leaking fuel. fuel regulator under hood could be leaking, this would cause hard start/ extended crank times. or Evap trouble.
Old Mar 12, 2007 | 05:31 PM
Puck's Avatar
Thanks for the reply chassis221. Sorry I didn't back to you sooner, but having a 6 year old on Spring break is keeping me busy!! Anyhow, the Little Lady starts just fine, so hopefully it'll be something simple like a leaky fuel filter, like you mentioned. Again, thanks for the reply, it was much appreicated!!
ABeardedMan
Oct 1, 2014 12:35 PM
Fixit
May 17, 2008 11:55 PM
KANEGRANT
Dec 30, 2006 02:45 PM
jdorencc
Nov 18, 2006 05:27 PM
kazacs
Sep 22, 2005 05:42 PM
