Engine poor idling and engine shaking
Old Feb 27, 2007 | 12:03 AM
Rockerfella174's Avatar
Default Engine poor idling and engine shaking
as many S class ive done...i found from time to time they have the problem of shaking engine and poor idling.- most of the time i found the fuel gauge at full or 3/4 full tank.
Ive diagnostic and found nothing wrong... its like fuel pump not functioning... even replacing it , it still the same...- the remedy for which i ve been advised was to pour in 200ml of 5-40fully syth engine oil in to the fuel tank. ive tried with S500,S320,S240,S600 and600SEL.
Amazingly after 5-10mins start the engine -its works!! Problem solved... -works properly 100% normally...- the funny thing is, when idiagnos the cars -i cant even detecting any fault codes ..
any advice ?...
Now my question is... is it safe? does it have any side effect ?
Old Mar 4, 2007 | 01:13 AM
car's Avatar
car
Default RE: Engine poor idling and engine shaking
MY S500 WHEN ENGINE IDLESTARTS TO SHAKE, AFTER HITTING THE GAS SHAKES SOMTIMES FOR ABOUT ONE MINUTE THAN GRADUALLY COMES TO A STOP. IF U HAVE SOME INTEL,PLEASEHELP ME. THANK U
Old Mar 4, 2007 | 09:25 PM
So far i dont have the side effects no engine shaking after i put in the engine oil only for 200ml 5-40 fully syth in the fuel tank.. i took the risk only to find out if the myth is true.
Rockerfella174
Brunei Darussalam
Old Mar 13, 2007 | 10:57 PM
97dmsrS420's Avatar
WOW, I'm sorry to hear this guys!!! Really I am! Have you all thought about checking the plugs and coils? Sounds like misfiring to me. Check any ways.
Old Mar 13, 2007 | 11:02 PM
vovpar's Avatar
shaking and poor idling can also be caused by a faulty MAF sensor. Sometimes it does not throw a code, but my problems went away after i replaced it with a OEM new one
Old Aug 29, 2009 | 09:42 AM
Ukiboy44's Avatar
i had a nightmare with my s600. spent about 30k after i already paid 28k for it. i just recently had a shaking prob, and it was the air mass sensor. cost. $380 at dealer and took 5 min to replace. it could also be a fuel filter and spark plugs. if u can try to look around for a problem but if you'd like u could start with simple things like changing oil or fuses of filters things like this
Old Sep 1, 2009 | 11:38 PM
damn ... MAF is so expensive ...but i did manage to replace it already thank you for the answer ...
Car : Mass Air Flow sensor is the culprit .. replace brand new
97dmsrS420 : Replaced already but same story until replacing the MAF - funny i didnt come out on the trouble codes
Ukiboy44 : Thanks for sharing info bro..!!
Vovpar : Fantastic answer thanks alot!!!
Rockerfella
Brunei Darussalam
Old Sep 6, 2009 | 08:23 AM
Ukiboy44's Avatar
no problem. so the air mass/ maf sensor was the problem?
e320.1995
Apr 4, 2013 12:27 AM
alliebenzy
Oct 25, 2009 07:11 PM
janowat
Oct 25, 2009 04:11 PM
miishmiish
Jun 11, 2007 06:37 PM
SLK320Chic
Sep 29, 2005 04:44 AM
