Check Engine Light
Old May 10, 2006 | 12:50 AM
MercedezGolf's Avatar
Default Check Engine Light
Hello everyone,
My check engine light has been on for quite a while now. I always assumed that it was just the 02 sensor. I finally changed the sensor and to my shagrin, the light remained. I would like to hook up to one of those on board diagnostic (obd) machines and see what it says. If anyone has any information on this or just has a guess as to what is causing the light to remain on, please feel free to speak up.
Old May 10, 2006 | 01:05 AM
sleepwalker's Avatar
Default RE: Check Engine Light
the O2 sensor if functioning as intended.
it's just a sensor to tell you that your car is running lean or rich.
that's the reason why the check engine lamp is on.
Old May 13, 2006 | 06:46 PM
vytamenc's Avatar
you cant just guess at this stuff there is a reason why the light is on there is a code for everthing you need to read it first then make the repair it could be a code po455 which could be something as simple as you have a lose fuel cap
nolen01
May 7, 2015 05:58 PM
solarant
Dec 27, 2007 11:34 AM
krisgt2@hotmail.com
Sep 28, 2007 01:41 AM
