calibrate leveling system
Old Oct 1, 2007 | 12:01 AM
dcsimmons's Avatar
Default calibrate leveling system
I have a 2000 S430 that recently had some work done (airmatic pump replaced, etc.) at a non MBZ Shop. I will never make that mistake again. Now the right side is always 1" below the left side. I tested it for leaks and there aren't any. I disconnected the airmatic pump and measured the height of each wheel, and then let it sit for 3 days. None of the measurements changed over a 3 day period of time so I am confident that there are no leaks.
My question is simply this. How can I recalibrate the leveling system.I reset the airmatic pump (by turning the steering wheel all the way to the right, then all of the way to the left, and then to the center, and waiting for 15 seconds), and the pump works fine. It raises and lowers as it should but the right side is always 1" below the left.
Any ideas. Does it take a complete reset of the ECU?
Any help would be very much appreciated.
Old Oct 1, 2007 | 08:10 PM
ARMENDS500's Avatar
Default RE: calibrate leveling system
there are sensors that tell it how high the car should be on all 4 corners, maybe the right side went bad, not sure thougth..
jefh
Jun 13, 2008 01:09 AM
tijoe
Apr 1, 2008 04:38 PM
dvmstr93
Apr 15, 2007 06:07 PM
gofaster68
Sep 18, 2006 08:54 PM
Benztime
Oct 4, 2004 02:29 AM
