Blown engine - Help!
Old 10-08-2006 | 05:02 PM
ajm's Avatar
ajm
Default Blown engine - Help!
I have an 86 420SEL with what amounts to a blown engine.
A piece of the plastictiming chain guide broke and got caught in the chain putting a hole in the driver side valve cover and presumably knocking the engine out of timing enough to cause those pistons to hit the valves - the drivers side cylinders do not have compression at all.
Anyway, my question to you is what to do now. I was thinking about putting in a used 420 or even 560 engine (depending on how difficult the swap would be), rebuilding my engine would cost about $7000 so that is out of the question.
Has anyone had this happen, and what can I do?
Thanks,
Andrew
Old 10-08-2006 | 06:24 PM
mbz300sdl's Avatar
Default RE: Blown engine - Help!
Best bet get another engine either the 420 or a 560 like u said though i am not a mechanic many of the parts on a 420 motor and a 560 motor are then same so i would assume that either would be a good choice i am assuming the rest of the car is in perfect condition cause it may be cheaper just to get another car and use that one for parts your choice.
Old 10-10-2006 | 03:33 PM
ajm's Avatar
ajm
The rest of the car is in pretty good shape. I was hoping to get a used engine and install it or have it installed for 1000-$1500, this may be wishful thinking i dont know.
Something so that at least i could get 10-20k more out of the car.
One big hurdle to simply buying another car is that in MD a car has to be inspected before it can be registered and this is usually expensive.
Back to work,
Andrew
gugufut3
06-13-2007 12:42 AM
e420helpme
06-02-2007 03:43 PM
bjrespect
05-14-2007 07:54 AM
wis
01-15-2007 01:27 AM
benzurfin
06-20-2006 05:01 PM
