600sel Transmission Problems
Old Apr 18, 2007 | 01:40 AM
rallyvw's Avatar
Default 600sel Transmission Problems
[align=left]Hello,
I am new to this Forum. I just bought a 1992 600sel and I am now having trans problems. The car had trouble shifting from 1st to 2nd when at full throttle(engine would bounce off rev limiter at 7k) then when I parked the car at work today no reverse, 1st gear or 2nd gear. It has 3rd and I am afraid to drive her home as I am going to tow her. I changed the filter and fluid 200 miles ago to try to fix the upshift problem but nothing changed. I noticed the fluid level is a little high and I corrected that....but no change. Any recommendations? Valve body? Thanks for your help!
Jon Hamilton
2004 Pikes Peak Production Champion
[/align][align=center] [/align]
Old Apr 19, 2007 | 08:57 AM
wmercer's Avatar
Default RE: 600sel Transmission Problems
Need to rebuild transmission. Consider other than a chain store such as AAMCO, rather find a local shop with either experience in MB cars or works commercial/trucks/fleets, as these shops will take the time to read the manual and follow the right steps. For me, it required a new valve body and normal bands replacement. A torque converter rebuild is a good idea also. In hindsight, I would have also spent another few hundred during the rebuild for a front pump, as mine has a whine. Expect to payalmost $4K if thepump is replaced also. Don't be disappointed if you have to take it back for another rebuild of basic parts only, if it doesn't get put together just right.
Old Apr 19, 2007 | 01:50 PM
Peter Guenther's Avatar
I would get a rebuilt, even my dealer does not do it any more unless they can identify the problem. I just looked up a price for my 500SEl and it was $3800 and did not even address core. I would find out where your MB dealer gets theirs. I know they useMB authorized parts like A/Compressors. I would also speak to some good indpendents
http://www.trademotion.com/partlocat...?siteid=213951
http://www.buymbparts.com/
Old Apr 20, 2007 | 09:09 AM
wmercer's Avatar
Buying a pre-rebuilt is ok also. I would stay with a MB authorized rebuilt, as any other, you would not know the conditions of the valve body, governor housing, case itself, etc. Only advantage in rebuilding vs installing a pre-rebuilt, is for about the same total $$, you usually can have more internal parts installed, where a pre-rebuilt may or may not had essential parts installed (valve body, governor springs, etc).
Either way works, I just favor the more new parts inside a rebuild of a transmission, the better, for the same price. Mostly because you do not want to have to take this thing out again.
Old Apr 21, 2007 | 01:21 AM
rallyvw's Avatar
I have a overhaul manual on the way. I am going to attempt the rebuild myself. I am not going to pull the tranny out till I read the overhaul guide....I still hope to be able to fix it in the car. The only obvious problem is the a wire is broken from the transmission overload switch. I will keep you updated on my progress.
Jon
Old Apr 22, 2007 | 10:00 PM
andygroove's Avatar
I had kinda the same problem on my 95 S20. It had a leaking transmission line. The car had very hard shifts and wouldn't even go into reverse. I took it right away to Midas and they diagnosed it, closed up the leaking line and did a tranny flush. All costed me 300 bucks. The car now rides smooth and very powerful and reverse works too. It's good to fix problems before it's too late. Try a tranny flush and see if that works.
Old Apr 23, 2007 | 01:45 AM
Rockerfella174's Avatar
This is the common problem to mb s600 or sel600 when that happens rebult auto trans is the only solutions...- ive come across about 7 units and each had spent around 3.8 k ... its that or replacing new ones cost you around 15 k at dealer ... indeed the price is killing you...
rockerfella174
Old Aug 26, 2007 | 09:09 PM
temkek's Avatar
Hi I am new to this site i am just looking for some advice my 500 SEL does not appear to be going into reverse fully all forward gears run smoothly is this a gearbox sensor greatly apprieciate any advice available Dave.
bluefjr130005
Oct 26, 2006 10:52 PM
92600SEL
Jul 23, 2006 07:53 PM
qha000
Jun 23, 2006 01:17 AM
92600SEL
Oct 9, 2005 09:02 PM
jonkoucky
Aug 12, 2004 08:37 PM
