600 SEL - Technical Problem
Hi I have a 1992 600 SEL. Recently, the orange ASR light comes on and the engine loses power. This problem occurs intermittently. If i stop and restart the engine, the problem goes away. Can anyone help with diagnozing the problem and offer a solution. Thanks |
RE: 600 SEL - Technical Problem
I have similiar ASR/ABS light on problems. Been chasing it for a long time. Any updates on your issues?
thanks. |
throttle valve\control unit problem. (EGAS)
well that narrows it right down. lets try to get some codes read. especially with these 140's with 120 motors. 1992 hell that could be anything. could be a throttle actuator could be a carb module could be a asr module hell anything. the only problem is each of those components start at $2000.
check the throttle adjusting cable, try to retard it, next step if the first one does not work, check the throttle actuator harness, been there before now I am enjoying my V12 after all the horrible experience, you don't really have to spend a fortune on that repair unless you want to.
