2000 S500 electronic fuse location
I have a (almost) dead S500. I checked all the fuses. The fuse chart lists a "Electronic Fuse". Can anyone tell me where the Electronic Fuse is located? Thanks, William
Key W/N turn, no headlights, no horn, no hazard flashers. The only things that work are: Trunk opens from drivers door, trunk lights work, windows shut with mechanical key. Tried new battery and had jumpers connected. No help. All fuses at rear seat read 12.8V and a few fuses under hood read 12.8V. It appears I'm losing voltage somewhere or there is some kind of lockout (which I doubt). I drove the car and laid it up all winter. Any hints? Thanks, William
William. I'm a little concerned that you are just going to the fuses for a voltage reading. This can lead to some erroneous conclusions.
If you are an electrical whiz and know the pitfalls, then please ignore.
"The fuse chart lists a "Electronic Fuse"."
I'm not sure what this is either. I would think that it is part of a substantial relay that is not being actuated for some reason. The conditions for that actuation may be determined by software, and therefore kind of a fuse action that uses electronic control.
The fact that lights and hazards are not working, indicates that it's not just the requirement for the key to be turned.
Wisjd
Feb 1, 2009 12:13 PM
