1999 CL500 (W140 Coupe) problems, HELP!
The car has been sitting for a while, mileage is over 105K. At this point the windows will not "drop" upon a door being opened, which causes the window to scrape the seal/gasket, and than closing the door shut is a whole another problem. Windows can be lowered manually, doors closed and than all window will roll up if the car is being locked with the key in the door key hole. Basically, the windows do not "know" when a door is being opened. The car did not have this problem earlier, and I wonder if it can be solved by some kind of a sync procedure. Thanks.
