1995 s320 heating/ac problem Help Please
HI again and thanks for everyone's help with my last problem!
Just turned on my heat for the first time this year and I can't get any heat from the driver side vents. Only heat from the passenger side. The AC works as usual. Any suggestions, thoughts?
Thanks for your help.
Shayne
Shayne
Hello,
Try switching or turning the center vent control, located on the buttom of the center louvers. they might be turned off, if not please be more specific with your problem, good luck.
It is not my vent controls. The air blows out of the vents, it is just cold on the driver side. No heat will come from the dirver vents. The a/c blows cold on both sides but when I turn both sides to a higher temp setting, heat only blows from the passenger side vents and cold air continues to blow from the driver side.
I suggest you to get a Factory Mercedes Manual.
It has all service and maintenance instructions, step by step.
A great help, hope this will help you.
Here's the link:
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMESE%3AIT
Here's the link:
patricknif
Mar 4, 2012 06:38 AM
MARIODRIVE
Nov 23, 2008 05:39 PM
