1994 s320 wont shift 3rd gear in the morning
Old 12-01-2008 | 06:48 PM
my_galaxy's Avatar
Default 1994 s320 wont shift 3rd gear in the morning
guys i need ur help
i have a 1994 s320 mercedes. when i start my car and drive it, it doesnt change 3rd gear. but if i warm it for 5 minutes then it works fine. once its warm then it drives normal. thanks
Old 12-10-2008 | 06:34 PM
94Mercs320's Avatar
Default RE: 1994 s320 wont shift 3rd gear in the morning
I am having the exact same problem with my '94 S320. I recently had the tranny overhauled and the issue started. My mechanic can't seem to fix the problem.
Anybody out there know how to fix this???? HELP!
Old 12-11-2008 | 05:53 PM
94Mercs320's Avatar
Here is our answer from a member of another message board.
"Many Mercedes are designed to hold a lower gear until the car reaches a certain operating temperature. The higher RPMs help the catalytic converter warm up more quickly to reduce emissions. My 96 SL320 and my 07 E550 both do this."[/align]__________________NeilSan Francisco Bay Area2007 E550, P1, Sport1996 SL320, ASR, Heated Seats, Xenons, CD Changer, My Cars: http://www.benzworld.org/gallery/sho...&ppuser=133412[/align]
Old 12-11-2008 | 07:52 PM
Wisegy123's Avatar
My 1995 S420 was doing the same thing.The check engine light was also coming on. I had the switchover valve replaced. But, it didn't solve the problem. I am now going to replace the AT Kickdown Cable (also known as the Boden Cable or Shift Control Cable). Hopefully, this will do the trick. I'll let you know.
Old 12-11-2008 | 09:20 PM
94Mercs320's Avatar
Thanks Wisegy123, my check engine light is on now too and I didn't thinkthe two wereconnected but could be.
I would appreciate knowing the outcome of your efforts.
Old 12-19-2008 | 07:40 PM
Wisegy123's Avatar
It looks like the problem was with the AT Kickdown Cable (boden cable; shift control cable). I had it replaced three days ago and so far everything is running fine. The check engine light has stayed off, too. Before this, I had replaced the switchover valve and oxygen sensor but was still getting the check engine light and the "upshift delay" fault code. Now, the car is running fine andit appears that all is well. I just hope that it stays that way. Good luck with your problem. Let me know how you make out.
Old 12-19-2008 | 09:28 PM
94Mercs320's Avatar
Thanks for the update! Can you give me a ballpark on the cost of replacing this cable?
Old 12-19-2008 | 09:30 PM
Les4Parts's Avatar
ok 04 S320 may be a 722.602 electronic shift transmission, I can't tell for sure without the complete VIN Number but if it is you may be looking at replacing item #20 which is the electronic circuit plate that mounts on top of the valve body. Time to visit your local Authorized Dealer and request an itemized written estimate of repairs.
  #9
Old 12-20-2008 | 07:09 PM
Wisegy123's Avatar
The part itself is around $185. You may be able to find it for less at some of the online parts suppliers. The cost of labor and installation would be added to that.
  #10
Old 12-21-2008 | 07:40 PM
94Mercs320's Avatar
Thanks Wisegy123. I'll look into that.
Quick Reply: 1994 s320 wont shift 3rd gear in the morning
