1992 S500 need great help
1992 W140 119 engine, S500
HELP PLEASE
Car run fine initially. Couple of months ago, the car was in Limp Home Mode. Check engine wiring harness found out the insulation of wiring harness to the throttle actuator and to the injector were gone. Replace wiring harness to the injector and re-wiring the throttle wiring harness. Put all back together the car run realy smooth. After using it for a month or so... the engine start real rough and into LHM. The RPM jumping up and down. Also black smoke coming out from the exhaust. Spray the Air Mass Sensor... no difference.
Check the rest of the wire - all ok.
Check all vacuum line - they are all ok.
Replace fuel pressure regulator - no difference.
Use a Trisco Palm Scanner (PS-411-BENZ) to read code and these are the results.
LH, HFM, ME(R)
Read DTC - system normal
Read store DTC, two codes appear. 05 and 10.
Code 05 says Intake air temp sensor shorted or open CKT.
Code 10 says O2S 1 signal, shorted or open circuit.
LH,ME(left) - No ECU control or no data.
ETC system - No data from vehicle
DM system - No data from vehicle
EDS system
two code, 10 and 13
Code 10 says No description.
Code 13 says Elec. Diesel sys. ctrl unit faulty (internal fault memory)
BM system - system normal
DI system - system normal
EA/CC/ISC
Code 224 says Idle speed contact switch S29/3 fault
EZL system - system normal
OP system - system normal
PML system
Code 03 says (1) LR wheel speed signal error. (2) LF wheel speed sensor and circuit fault (W129/W140 since 94)
Code 04 says (1) RR wheel speed signal error. (2) RF wheel speed sensor and CKT fault (W129/W140 since 94)
ABS/ETS/ESP - system normal
BAS system - no ECU control or no data.
ADS system - data error
ASD system - data error
SPS system
Code 11 says Volts supply at speed sensitive power steering Ctrl module faulty.
Code 17 says no description
SRS system
Code 139 says no description
Code 03 says low volts, voltage supply circuit 15R
ICM system - no ECU control or no data
RST system - system normal
RB system - data error!
IRCL system - communication interrupted
PSE system - system normal
ATA system
Code 15 says IO SIG not received from interior motion sensor or button on interior motion sensor transmitter and receiver unit pressed at least once or infrared interior motion sensor control unit (N26/3) not present or defective
CF system - system normal
AC system - system normal
OCP system - No ECU control or no data
LCP system - No ECU control or no data
PTS system - No ECU control or no data
EIS system - No ECU control or no data
D2B system - No ECU control or no data
Try to delete the codes, however the following codes cannot be erased.
EA/CC/ISC
SRS system
Sleepwalker, lugnut, mbz300sdl, c280 wizard, k1motorsport, snanceki, and all people from forum.... Please HELP...
HELP PLEASE
LH, HFM, ME(R)
EDS system
two code, 10 and 13
EA/CC/ISC
PML system
SPS system
SRS system
ATA system
EA/CC/ISC
SRS system
RE: 1992 S500 need great help
Thanks Bill.
Have check all wiring in the engine bay. They are all good.
I have disconnect the battery several times now and the problem still there.
Clear all code but these codes keep coming back. And they are:
EA/CC/ISC
SRS system
Please help...
EA/CC/ISC
SRS system
Please help...
mr.maybach*benz*600
07-09-2008 09:08 PM
Johnrude
12-09-2007 02:43 AM
europeancardrvr
01-17-2005 11:09 AM
