1987 420SEL Windshield Wipe Tension Spring Unhooked - how to put it back?
Old Oct 1, 2023 | 02:29 PM
chenxinghao's Avatar
Default 1987 420SEL Windshield Wipe Tension Spring Unhooked - how to put it back?
In an effort to replace wiper blades I pulled the aim back as much as I can. In doing so I accidently got the tension spring unhooked (don't know how it got loose) from the arm head. Now I have difficulty to get the hook back as it was because I am unable to pull the spring enough - with a long nose plier - to get the hook on again, even with the arm off the motor housing.
I need advice on ways to get the spring hook back on again. Thank you.
Old Oct 3, 2023 | 12:49 PM
There are Wiper Arm Spring reinstall videos on Youtube for other brands of vehicles using Drum Brake spring Plier. For one thing, I am not sure that the "anchor" hole on my W126's Wiper Arm (which looks like just a "dent" on the surface) is deep enough for the plier to get a solid hold and I don't have a such plier in the garage; for another, I wanted to see if I can use whatever I have and get the job done. So here is a list of what I used:
(1) A household wire cloth hanger - make a long hook with the spring.
(2) A piece of scrap wood, about twice long that the wiper arm
(3) Left-over screws and bolts+nuts
(4) Typical household tools
From the following photos, you get the idea how it was done from the setup on a foldable bench:
Now, the wiper arm with a new blade is installed on my 1987 W126 420SEL which is ready for the winter.
red93
Mar 11, 2014 12:36 AM
Sepherial
Feb 26, 2010 02:03 AM
Jim Cahoe
May 3, 2009 11:41 AM
kayla
Nov 27, 2007 01:09 PM
hercar
Apr 8, 2007 03:44 PM
