Mercedes R Class Mercedes R350 and Mercedes R500
Check Engine light
Old May 28, 2008 | 02:04 PM
icr350's Avatar
Default Check Engine light
[X(]My R350 currently has 16000 miles and check eninge light came on, has this happened do some of guys? What was the problem??I am taking it to the dealer this weekend and see what is going on. I think it is too soon for that to happen.
Old May 29, 2008 | 12:08 PM
AMGMercedes's Avatar
Default RE: Check Engine light
If could be anything from scheduled regular maintainance to total engine failure. Who knows really without the code.
Old Jun 10, 2008 | 09:49 PM
jumpback's Avatar
Last poster was correct. The car needs to be checked out with a computer. Many local auto parts places will do this for free.
Sometimes it can be something as small as a loose gas cap.
Old Jun 11, 2008 | 03:31 PM
gilgorm's Avatar
I've had a Check Engine light twice on two different cars. The first time it was a loose gas cap that reset days after I found the problem.
The second time I needed a new O2 sensor. The car had 16,000 km on it at the time. I was told that some O2 sensors can fail particularily in the spring when a drastic season change occurs.
Either way your "R" must still be under warrantee and should cost you $0 at the dealer.
There could be any number of other problems that only a code can point to.
Old Jun 13, 2008 | 03:18 PM
bro_hof's Avatar
My R had the CE light come on at 15k miles...it was the camshaft position sensor. No other indication something was wrong except for the light. Good luck!
nolen01
May 7, 2015 05:58 PM
solarant
Dec 27, 2007 11:34 AM
krisgt2@hotmail.com
Sep 28, 2007 01:41 AM
