Mercedes R Class Mercedes R350 and Mercedes R500
2006 R350 rear lights
Old Oct 22, 2009 | 09:07 PM
Bruce01's Avatar
Default 2006 R350 rear lights
My R350 has approx. 52k miles and I have replaced all of the 6 tail lights and I am still getting a message from the dash control center stating the lights in the right and left are having issues. Has anyone else had this problem?
Thanks,
Bruce
Old Nov 1, 2009 | 12:42 AM
barkysbro's Avatar
Default This happened to me at the same mileage..
It is a known problem with the tailight circuit board. Apparently the fix is to resolder some loose connections. THe MB dealer in Las Vegas fixed it for me in one day , under warranty, while we were driving through there on vacation in June.
Old Nov 1, 2009 | 07:35 AM
chassis221's Avatar
needs an updated wire harness and ground. you need to remove a wire from the connectors and insert the wire into a new harness. both sides need the update.
Old Nov 1, 2009 | 08:07 PM
barkysbro's Avatar
Default That sounds like a much more realistic description..
Guess the service writer in Vegas "dumbed it down" for me.
Old Nov 13, 2009 | 08:12 PM
Bruce01's Avatar
Exclamation R350 2006 rear lights
Thanks for all the inforamtion about the rear lights. It was the rear wire harness for the tail lights. I called MBUSA about this problem and there has been a technical bulliten issued for this problem by MB. They recognize the mechanical and engineering problem and the customer has to pay for the repair? Seriously! It is not the out of pocket expense, it is the added frustration and just owning up to mistake by the manufacturer which should be repaired by the MB.
SliderJeff
Feb 6, 2012 09:18 PM
jmjbm
Jul 19, 2010 10:09 PM
xuzhupa
Dec 31, 2009 02:05 PM
slick1
Jul 30, 2007 07:05 PM
pon3y
K1 Motorsport
Jun 13, 2006 07:13 PM
