Possible Bad Key-DAS problem?
Old Jan 9, 2009 | 01:52 PM
Newfiemz3's Avatar
Default Possible Bad Key-DAS problem?
Just purchased 1998 ML320 and won't start. Vehicle has been laid up for about a year and during that time the battery was ran down and charged a couple of times and vehicle started, but it has not been started in several months. Charged battery and even tried boosting , all to no avail. The engine cranks, and even catches on occasion , and then just dies. All cluster lights come on and is showing RPM movement the odd time that it does catch for a brief moment.Neither of the three keys I have will work, although the remote locking function is fine, re-synched the keys, no go. It is giving a code of P1570, indicating a communication error between ignition and ECM, conclusionAS is not recognizing either of the keys....or a faulty DAS ring........but....also neither of the keys turned to position II will give the quick illumination of the security light.......which leads me to conclude that all the keys are bad........is that possible? Or just really bad luck?
If so, can these keys be reprogrammed without the vehicle at the dealership......or do I have to purchase new keys and tow the vehicle to the "stealer".
Or, could it be something totally different.........faulty DAS.
Is there a quick fix? Can I disable the antitheft to by-pass this issue. Any advice greatly appreciated.
Old Jul 11, 2009 | 01:53 AM
mdaia's Avatar
i have the same car I had the same problem with 2 of the keys.be careful mercedes only makes 8 keys per lock
Old Jul 11, 2009 | 08:45 AM
chassis221's Avatar
its not a key program issue, it should still start your car. could be the ring around the ignition where you put in the key. its sort of an antenna that recognises the key. maybe you have a fuel pressure issue?
allen446
Dec 4, 2008 03:05 PM
renatopent
Mar 31, 2006 07:30 AM
cesarr26
Dec 15, 2005 01:42 AM
cesarr26
Dec 13, 2005 01:50 AM
necarlitos
Dec 3, 2005 10:13 PM
