O2 sensor heater problem Need help of specialists
Old Feb 8, 2006 | 09:28 PM
kora's Avatar
Default O2 sensor heater problem Need help of specialists
Code - p0135. Changed o2 sensors, MAF, and plugs. CEL is still on. Data on wires: Grey ground - OK, Black sensor data - OK, White heater 12V -OK, white heater - no ground. Could not find a wire diagram anywhere.
Questions: Is it a wire harness problem? Is there a relay between O2 sensors and ECU? Where it is located. How to test if ECU grounds the sensor?
Old Feb 8, 2006 | 10:30 PM
sleepwalker's Avatar
Default RE: O2 sensor heater problem Need help of specialists
and what engine does that M-Class got?
Old Feb 9, 2006 | 05:01 PM
kora's Avatar
Sorry. ML320, 2000, 3.2 l engine. All 4 Os2 sensors have the same problem - heater. I am not aware of heater circuite diagram. Do the heater wires go directly to ECU or through a relay? Do they go separately to ECU (I doubt that), thus where is the meeting point? Thanks again
Old Feb 9, 2006 | 10:50 PM
ok, got it.
[IMG]local://upfiles/1/2407418D41C84930BA12CCEAC723B9AA.jpg[/IMG]
Old Feb 9, 2006 | 11:00 PM
[IMG]local://upfiles/1/394A22F904744AA09D53397B281DD5F5.jpg[/IMG]
[IMG]local://upfiles/1/627C2A35D9E545D5955C5C1585255FA3.jpg[/IMG]
[IMG]local://upfiles/1/2866AA043E9242DA903B7E95D38744A9.jpg[/IMG]
Old Feb 10, 2006 | 10:14 PM
kora's Avatar
Super. Thank you. So no relay, no common wire to the ECU. O2 sensors are working in pairs separately. The ECU transistors govern grounding of O2 sensors. I wonder if the ECU heater switch gets the signal from a temperature gage or from the O2 sensor itself? Can't read the ECU pin numbers, do you have a picture of ECU pins?
Thanks a lot
tonyn007
Oct 5, 2020 02:20 AM
slkrider123
Apr 9, 2012 04:56 PM
builderdude
Sep 16, 2010 11:17 AM
mercedes86
Oct 16, 2009 06:25 PM
