ML430 cutting out not starting
Hi ive been reading posts here for some time hopefully someone can help me with my anoying problem
the car is a 2000 ML 430 and it doesnt start sometimes for no real reason ill drive it round all day stop for 2 mins the it just
turns over and over but doesnt fire up took it to merc and they said it was the startet playing up even though it turns the engine
over fine and the car can go for a week without doing it they "serviced " the starter and its made no difference
now its got worse yesterday it stopped after about 10 mins of trying to start it (thats about how long it takes before it starts)
it started i drove about 4 miles then it just cut out and wouldnt start again this is the first time its done it when its running
had to get the car tranported home when i got home it started on the back of the truck and i drove it off
it has always started first thing in the morning it only happens after i have driven it
this is begining to drive me mad merc arent helping on there computer the said there wasnt any fault codes ?
i think it a pretty bad fault myself any help would be really appreciated
thanks in advance
Stuart
thanks in advance
Stuart
hi again it seems like it could be the cps can anyone tell me where abouts it is on the flywheel and is it worth replacing it with this item
http://oem.thepartsbin.com/parts/the...ensor&dp=false
has anyone used these people it was the first place that came up in google
thanks
thanks
thanks for the info changed the sensor it seems fine so far as a bonus changed the air filter when i was looking around under the bonnet
and the car runs much better even though it has full merc service history and 1355,000 miles the filter was really dirty time to change merc service center
i think
i think
I just purchased a used 2000 ML430 and drove it home an hour and a half, washed it . Started it and it just kept clicking not turning over. A single wrench is shown on dash,minor servicing.Waited n went to dinner, stopped for cleaning supplies, went in and out started no problem. when we left resturant it wouldnt start, an hour. Called tow, before it arrived it started , tried moving and died in parking spot. Got it home . That night i moved the car drove around parking lot and died again.. Now 2 wrenches, major servicing. I than drove a half hour 2 days later, parked got out n wouldnt start. Now im having it serviced. Like everbody says diagnosis says nothing. Thanks to your forum i believe it's the CPS. Im having it replaced now praying that is it. Tomorow i will know. Any info regarding this I will greatly appreciate. Ill let you know how it goes..
