ML320 Would not Start sunday.
Old Aug 18, 2004 | 12:33 AM
sdanville's Avatar
Default ML320 Would not Start sunday.
then it started. then didnt start at work. waited 14 minutes..then it started.
1998 ML320 101,000 miles.
Old Aug 18, 2004 | 09:23 AM
sleepwalker's Avatar
Default RE: ML320 Would not Start sunday.
AAM (all activity module) got CAN (controller area network) interruption signal to EIS (electronic ignition switch).
Old Aug 18, 2004 | 10:34 AM
Lugnut's Avatar
Does that translate to brain fart?
Old Aug 18, 2004 | 10:45 AM
mainly if the car cannot start, it is the engine control unit that's faulty, but this M-Class is one of kind.
whenever the customer calls the "car cannot start", i immediately grab an AAM control unit.
Old Aug 25, 2004 | 01:21 PM
sdanville's Avatar
My ML onlyu failed to start one more time. The last couple days it started. I stopped using the "Blade key" that I have used exclusively for the past 18 months.
one mechanic advised not to use that one.
Old Aug 25, 2004 | 08:37 PM
using the keyless go card is another story.
sometimes you will get interruptions, low battery on the card, or antennas inside the door.
di you get the "check card" message?
Old Aug 29, 2004 | 01:21 AM
sdanville's Avatar
Default yep yep nope yep yep nope,.
No check card message. I drove it successfully 3 days - started great.
Then it took two try's to start leaving the store today. Unnerving.
Old Aug 29, 2004 | 06:10 AM
Default RE: yep yep nope yep yep nope,.
card location signal frequency problem.
it will easily recognise the card if you hold it near the door because there is antenna reciever on every door.
Old Sep 2, 2004 | 01:07 PM
  #9
sdanville's Avatar
Default key - starting problems .
I thought the antenna was in the circle where the key went into the ignition.
My truck failed to start yesterday. waited 30 minutes and it started.
Now I notice a buzzing noise behind the intake manifold when the key is on and engine not running.
Any ideas what that could be ?
I thought maybe I needed a fuel pump or flter, but it goes 90MPH + and small spray came out of the fuel tubing check valve.
Old Sep 2, 2004 | 07:01 PM
  #10
Default RE: key - starting problems .
so the blade key you mean is the flat key, and not card key.
the one on the ignition switch is called transponder. it reads the resistance signal from your key, and can identify it.
what you got behind the intake manifold that can produce this sound was the throttle valve and a diverter flap. if the throttle valve is losing the program on it's initial position, then it will try to keep on moving to search for it. it's more of a click than a buzz. better open the hood and listen where it's coming from.
i still think it was AAM.
