ML320 W164 couple of problems
Old Jan 7, 2012 | 09:28 PM
b0gd4n's Avatar
Default ML320 W164 couple of problems
I have an ML320 cdi from 2006.
The problems I have are:
- the left mirror does not adjust (only the right one works) - I have tried to look for the fuse, but I don`t know where it is - I only hope this is the problem;
- an error message keeps popping up in the instrument cluster about a bulb;
I have recently changed the left rear indicator bulb, but this works well most of the time, until the error appears. This is after using the left indicator for a bit. It then uses the reversing lamp instead of the indicator bulb.
This is reset after I restart the car.
What should I do about this.
Thanks in advance!
Old Jan 8, 2012 | 10:57 AM
chassis221's Avatar
you probably have a bad mirror switch.
you could need a new tail light or a tail light harness update repair.
Old Jan 8, 2012 | 04:47 PM
Moto One's Avatar
We had a bulb that was not seated correctly, after reinstalling it all has been well.
Mark
MercedesW164
Dec 7, 2014 10:40 AM
ml320cdi-guy
Dec 3, 2013 01:22 PM
ml320cdi-guy
Mar 18, 2013 08:14 AM
david_ML3502006
Nov 23, 2006 03:13 PM
stuz
Aug 17, 2006 12:53 PM
