me light...is off
Old Sep 24, 2009 | 07:58 PM
ispt17's Avatar
Default me light...is off
Hi I have an ML320 2002 V6 and the light stop working. it's possible to replace it? THX
Old Sep 25, 2009 | 08:17 AM
mbenz80's Avatar
Yes, it is possible. Too bad I didn't take pictures when I was repairing my own. You have to take it apart all the way down to display. There are 3 little light bulbs soldered into display circuit board and all of them are burned out. What I have done, I cut off one of the side bad bulbs about 3mm above circuit board leaving wire legs for connecting new bulb to it. I used one 12V 1.2W or 1.5W bulb same as in the speedometer cluster and control ***** of older Mercedes models (same as subminiature wedge base bulb #73 or #74). Streightened connecting pins of this bulb and placed it sideways under and in the center of the display holding it with tweezers between board and display and soldering it to two wire pins left over from removed burned out bulb. This is my own procedure without desoldering and completely removing out (fragule looking thin) display.
You can use 12V LED of any color you wish for instead. I may have little more light with this single bulb then with original 3 bulbs (mine was burned out already when I bought it) so I can't compare but I'm very happy with it now and it's working daily for 2 years since I did this repair. Good luck!
Bernard
christop
May 16, 2010 11:29 PM
RIGGERBEAR
Nov 1, 2009 03:57 AM
springhillmb
Sep 21, 2007 01:41 AM
