Cylinder 3 misfire
Old May 8, 2013 | 05:14 PM
Ml320DB's Avatar
Default Cylinder 3 misfire
The check engine light came on, autozone put the code reader on it, the code came back cylinder 3 misfire. I changed plugs, reset light (by disconnecting battery for a minute or so) hooked up code reader and still read same. Changed wires, reset battery, still same misfire. So, then I switched ignition coils... I put cylinder 3 coil on #2 cylinder, to see if number two cylinder would misfire.... After the reset, put the code reader on it and now it reads cylinder 6 misfire.... Help!
Old May 14, 2013 | 12:04 AM
go-part's Avatar
Former Sponsor
davidlawsonrn
Oct 12, 2009 09:52 AM
taitsu
Aug 5, 2009 10:31 PM
mfotovati
Dec 3, 2008 12:50 AM
sixsense
Dec 23, 2005 11:22 PM
