Changing front light bulb?
RE: Changing front light bulb?
your better off taking the headlight off remeber to mark with tape exactly where the the three screw holes are and the light sits,then the moldind under the light squeeze the tab but dont take off completely let it swing open then the the other two screws are under that.take out headlight and change the bulb... sounds harder then it is or you can scratch your knuckles up and lose the cover or drop the bulb lolo have done this myself and it is better way just be careful and mark the top tab where the scew is so you can put it back where it was good luck
ORIGINAL: bamba
drfil
11-08-2011 09:03 PM
