2012 ML350 BlueTEC review
Old Feb 13, 2012 | 11:35 AM
Kingfish's Avatar
Default 2012 ML350 BlueTEC review
Howdy all,
Here's a link to a review I did recently on the 2012 ML350 BlueTEC. I spent a week with the car courtesy of Mercedes' press fleet and absolutely loved it - I'd hoped for some snow to evaluate the awd system, but no such luck. (the upside to global warming in CT?) I'd like to hear from ML350 owners and others familiar with the breed.
Will
2012 Mercedes ML350 BlueTEC: Diesel Improves the Breed - Hartford Hartford Cars | Examiner.com
Old Feb 14, 2012 | 09:53 AM
Kingfish's Avatar
Originally Posted by ForcedInduction
Did you tell your readers it has a $5000 exhaust filter that has to be replaced every 5 years? Or that it consumes synthetic-pee that costs $300 per tank to fill?
If you have the dealer top off the 7 gal AdBlue tank, it's about $220. (local quote) M-B sells their AdBlue (aqueous urea) for $20/gallon, but the same stuff (32% solution) can be bought at farm supply or auto supply stores for $6 per 2 gallon bottle, total cost $24. The tank lasts 15,000 miles +/- so it should be good for a year or better, typically. As far as the exhaust filter, if you're referring to the DPF (diesel particle filter) in the exhaust there is no replacement interval. It's only replaced if it's damaged. (This came directly from M-B)
Old Feb 15, 2012 | 09:53 AM
Kingfish's Avatar
Right, 5 years is MAXIMUM. It will likely fail or become plugged much sooner.
False.
Like all filters, it has a limited capacity. Once its restriction becomes too great, the only option is replacement of the entire exhaust system. Their filters cannot be cleaned like larger diesels.
Mercedes DPFs aren't self-cleaning? (will have to ask MB about this) Even VW's TDI particle trap has a regen function which cooks off the accumulated soot on a programmed cycle. Where did you get your 5 year figure from? Even if it couldn't be cleaned, why would that require replacing the entire exhaust and not just the particle trap? This doesn't make sense.
Old Feb 16, 2012 | 08:55 AM
Kingfish's Avatar
I am curious about the ash buildup issue, and will ask MB about it. The idea of a single-component exhaust sounds crazy, and I've never heard of anything like it, but I can see how a whole new system could run up to $5k.
Kingfish
May 18, 2012 09:05 AM
m110cut
Sep 8, 2011 10:02 AM
pedirn308
Dec 15, 2010 11:53 AM
