Mercedes G and GL Class Mercedes G500 and GL450 SUV.
GL450 Cold Weather Issue
Old Jan 6, 2025 | 11:39 AM
Luth1's Avatar
Default GL450 Cold Weather Issue
Having an issue when the weather drops below 45 degrees, the GL goes crazy with lights and will not go into gear. Goes into safety mode. We have replaced the main battery and cleaned the connections. That worked for a short time. We can reset the be removing the negative and it resets and is fine. There is no Aux battery warning at all. Not sure if that needs to replaced. Same issue this morning since it was cold, we removed the negative, reconnected started up fine. left it for about an hour went back out and it went haywire again. Any thought? No issues with warmer weather....
evomind
Aug 31, 2023 11:34 AM
Viktor Jenei
Mercedes A Class
Jan 20, 2022 09:13 AM
FilipeOS
Mar 5, 2020 03:09 AM
rdarvish
Feb 27, 2009 03:27 PM
wurkenman
Dec 4, 2008 05:23 AM
