Where i can find oil dip stick on E500 ???
Hi everyone,
It might be funny question but how can i check how is my oil in my 2003 e500?
I looked over 10 minutes and couldnt find dip stick. All i found was transmission stick in the back of the engine.
Thanks for your help.
RE: Where i can find oil dip stick on E500 ???
There is none,you look up the oil level in the FSS system 8qts. u.s. 7.5 liters with filter 229.5 spec mb oil mobil 0w40 syn.
you have no dip stick for the trans either,it is a sealed cap,that if pried off to check fluid level requires purchase of a special fill check only stick.
look up in your manual the procedure to check oil level,engine at op temp,car on level ground and procedure to call up that section of the dash cluster display.
ohlord
ohlord
With the car in a leveled position, engine off, ignition on check in the steering wheels buttons and find the proper info in the display in front of you, It takes about 10 seconds to appear. these cars doesn´t have an oil dip stick like the W210s.
IKE
07-31-2008 01:44 PM
