w124 E420 AC problem. HELP!!!
Old Aug 2, 2008 | 12:09 PM
jmang09's Avatar
Default w124 E420 AC problem. HELP!!!
94 E420 (150K miles)
Bought it with AC not working
Replaced blower motor fuse,
Replaced climate control unit in dash (old one was burnt out).
Problem: Blower motor will not run (in all settings), auxiliary fans will not run when AC is on, and the compressor will not engage.
When I turn the AC on I hear a slight hiss from underneath the dash, is there a vacuum leak somewhere?
What should I check/replace next?
Any help is appreciated. Thanks.
Old Aug 2, 2008 | 12:37 PM
ohlord's Avatar
Banned
Default RE: w124 E420 AC problem. HELP!!!
Go get partial charge or do it yourself and see if that triggers the compressor,if so you need to locate the leak and repair it,flush the system and have it properly refilled.
ohlord
Old Aug 2, 2008 | 12:55 PM
jmang09's Avatar
I have tried to charge it and still nothing. It is as if the compressor does not accept charge.
rainhopper
Jul 19, 2010 01:00 PM
benzsu
Jan 3, 2008 12:06 PM
TheV12pwr
Jul 9, 2007 09:51 PM
luisumf
Apr 9, 2007 12:35 PM
cruton3155
Sep 9, 2006 05:37 PM
