Transmision on 98 E320 swtching gears. Please help !!!
Old Feb 18, 2005 | 03:39 AM
CCCP's Avatar
Default Transmision on 98 E320 swtching gears. Please help !!!
Hi everyone! I have 98 E320 with 80K miles on it, and one of the things which bother me is how the transmission switches the gears. When it swithces from 1st to 2nd gear the car is kind of pulling back and then kind of jumps forward (especially when the "S\W" switch is on "S" ) or maybe other way around...... but if the RPM does not go over 2000 it's almost not shaking (just a little bit) It really bothers me a lot, because I think that something is wrong with transmission...... My friend has a 99 CLK320 and it doesn't do this kind of "shakes".................. CAN ANYONE PLEASE TELL ME WHAT IS IT THAT BOTHERS ME SO MUCH ???
Thanx all.
Old Feb 18, 2005 | 04:37 AM
sleepwalker's Avatar
Default RE: Transmision on 98 E320 swtching gears. Please help !!!
try checking the ATF first.
Old Feb 18, 2005 | 04:44 AM
CCCP's Avatar
I've checked the fluid.... looks fine..... still has some red in it..... well, I'm about to change it....
Do you have anything elso on mind what could it be ?
Thanx.
Old Feb 18, 2005 | 04:52 AM
MioCLK's Avatar
This is normal when the car isn't "warmed up"
First gear will take the engine up to higher rpm (about 4000) before shifting to second gear. This design helps the transmission to reach normal operating temperature faster.
Its more noticeable in S mode because W starts wtih second gear, instead of first; this helps traction in rain/snow.
i'm still trying to guess what transmission you got.
your car is 210 and transmission is 722.605....right?
Old Feb 18, 2005 | 05:09 AM
CCCP's Avatar
Honestly I don't know what kind of trans do I have...... yes, I think it's 210 (just basic E320 model line from 96-99) the one with round headlights.....
Old Feb 18, 2005 | 06:03 AM
722.607
as what Mio said, it must be a normal thing but you just feel a little of shifting engagement.
you were complaining of the engine too. sometimes if the engine got some problem, you might mistaken it for a transmission.
just replace the ATF first. sometimes it solves the problem... and you will change it anyway.
if the transmission is really fault, you will get a malfunction indicator lamp and a fault code is stored. (you got electronic transmission).
the oil smells like burnt or smells like a hundred dollar bill?
Old Feb 18, 2005 | 09:29 AM
Lugnut's Avatar
It does that high RPM "cold shift" to light the catalytic converters faster, not warm up the trans. Also, "shaking" during the shift isn't normal. It only takes once through the gears on mine. I live in a mild climate, but it gets into the 20s here on occasion. Still only once and no shaking.
Old Feb 18, 2005 | 01:19 PM
  #9
CCCP's Avatar
Yes, it is only one "quick" shake........but this shake "moves" me in my seat
O "S" mode it shakes on switching from 1st to 2nd and from 2nd to 3rd.....and on "W" mode (MioCLK said it starts from 2nd gear) it only on the switch from 2nd to 3rd.....
Old Feb 18, 2005 | 04:57 PM
  #10
Lugnut's Avatar
Well, it does indeed seem to be the cold start shifting.
Your car jerks once during the 1-2 and 2-3 shifts after a cold start. It doesn't shake. Is that right?
Your car revs to a higher RPM than usual when it shifts, but only when it's cold. It doesn't make strange sounds like a '65 VW that are so loud that it's driving you crazy. Is that right?
Nothing's wrong with your car.
