Testing Engine Compression on '94 E320 HFM engine
Old May 14, 2005 | 01:53 AM
allan l's Avatar
Default Testing Engine Compression on '94 E320 HFM engine
Hi Guys,
Any advice on the best method of checking engine cylinder compression on Ser 104 engine (with HFM controls) ?
I was proposing to :
1. Remove Fuel Relay
2. Disconnect low voltage inputs to the 3 coil packs. Then remove one plug at a time.
3. Use a screw-in Engine Compression Tester to check pressure.
Your comments would be welcome.
allan l
'94 E320 Coupe
Old May 14, 2005 | 03:22 AM
sleepwalker's Avatar
Default RE: Testing Engine Compression on '94 E320 HFM engine
better remove all spark plugs to reduce load from the battery.
removing the connector from crankshaft position sensor on EZL will also disable the ignition.
yes, screw-in type is better.
crank 8 times is always better result.
do wet compression test too. you might need the value for making decission.
Old May 14, 2005 | 07:02 AM
allan l's Avatar
Sleepwalker,
Many thanks for your advice on above exercise.
How do you do a "wet test" on cylinders ?
allan l
'94 E320 Coupe
Old May 14, 2005 | 10:04 AM
can spray a little penetrating oil on the cylinder wall.
Old May 14, 2005 | 01:00 PM
allan l's Avatar
Sleepwalker,
Many thanks again for your latest advice.
allan l
kamata
Apr 27, 2011 05:45 AM
raffo
Jun 10, 2009 12:01 PM
wam
Dec 4, 2006 04:00 PM
rkpatt
Feb 6, 2006 09:47 AM
Slayer
Feb 9, 2004 08:21 PM
