Strange electrical problems
I have an 1998 E320 sedan and have had a few strange problems.
1. Doors won't unlock with the FOB intermittently and when I try to lock them with the FOB, no lights flash and doors don't lock.
2. Sometimes the windows won't go up/down and no express feature..changes from one door to others....never the same door twice in a row.
Is there a control module that controls all this?
I recently had to install a LR window regulator. but that's all I ve had to do in the recent past.
Any insight on problem and parts would be appreciated.
Check the ground cable from the battery to the body. I fixed a herd of weird electrical problems on my 97 E300Dby cleaning it up with sandpaper and adding a washer to get a good tight connection to the bodyground.
i recently had a problem where my front windows would not go down and my side windows would not adjust. my trunk also wouldn't open by pushing the button or using thefob. i thought maybe my console switch had gone bad sinceall these functions are inone switch (cost $350) I 'm not a person to throw an expensive part at something for troubleshooting. On this forum I found a post about unplugging the battery, waiting a few minutes then plugging it back in. I tried it and now everything works. I did have to perform the Normalization procedure after unplugging the battery.sounds like you are having similar problems. make sure you have your radio code before unplugging the battery.
dcloeb
Dec 22, 2010 07:32 AM
khwaja
Mar 18, 2009 05:34 PM
