Smart Key
Smart Key
My Smart Key will lock and unlock the door but when I insert the key I can't turn the key into position 2, the key just stays in position zero. This happened after I checked one of the tires with a jack, activating the tow protection, and tried to start the engine.
Can someone help me? How can I turn off the tow protection? My car is a E430 1998.
Thanks.
Thanks.
RE: Smart Key
there should either be a button on the dash, and an option in the multi function display. of course, i suppose you cant access th mulitfunction without the key on, huh?
there should be a section in the owners manual that explains the entire function of the tow sensor. i know it sounds dumb, but those things can be incredibly helpful. it probably says something about how to reset the sensor once its been tripped.
RE: Smart Key
My E300TD won't make start circuit; New battery, Mercedes road service spent 4 hrs trouble shooting and could bypass start circuit and spin engine over but was no fuel. They said there was a start signal into the fuse/relay module with start relay but no signal out . I purchased new module but no change, its like there is a start lockout in play preventing start curcuit initiation.The air/vacuum pump next to the battery in rear seat short cycles when key is in the "on" position. when key is off I can hit remote door lock and the pump comes on momentarily for 1 short cycle to make up the air loss for locking.appears there is an air leak when key is in the "on' position.Help , thanks, Don
burryo
03-29-2006 12:36 PM
