"Service Threshold Reached"
Got a E500 211. Have a code for brake system T249F "Service Threshold Reached". Not sure what to do...Thanks in advance...
Hi Leshchuk,
My E wdb 211 046 too are having the same problem code : C249f Service threshold reached i too still waiting for a reply hope some one can help us out..! rockerfella174 |
The threshold that is referenced by that code is for the brake pump staying on too long before building pressure. May need assembly. If you retrieved the code then your mechanic can communicate with the SBC hydrolic system and replace unit and bleed. Good Luck!
Originally Posted by Rockerfella174
(Post 127807)
Hi Leshchuk,
chassis221
Hi chassis221 do you have a number to contact you? I need service on a 2006 e350 please call me at 267-333-3289 Sonny or : cruzmcauley@yahoo.com
please call me 267-333-3289 sonny i need service on a 2006 e350
AS replaced how do I reset the codes
I need info on how to reset eveything now that I put a new ABS pump in which Benz said was out of warrenty. The red no drive light is on in the circle and I have 3 codes which I will retrieve and add to this post.C1617,C21C,C26EC
Originally Posted by luweegy
(Post 165169)
Yes it is.My Benz dealer in Denver said it was out of warrenty.So I bought the part and installed it.I've tried to dissable the system to bleed it with my Solus Pro and it never completes the cycle and says cycle key and try again.I removed the ground on the trunk battery befoer I did this. My Email is evilzr1@gmail if that is easier for you.Thank you for the help. Finally got it to Activate and all is good.
