Restoration of a 190e
Old Dec 20, 2005 | 03:44 AM
Andrew Maris's Avatar
Default Restoration of a 190e
Hello all. My name's Andrew and I am new to these forums. I recently purchased a MB 190E 2.3L, and I am currently working on fixing it up. This car is nice, for a 91, the interior is almost perfect, as well as a huge upgrade from my old car ('85 Nissan 300Zx). At any rate I have a few questions:
- There is a rattle in the dash that sounds like a duct door rattling. I have heard the same noise in two different MBs. What is it, how do I fix it?
- How do you get the left rear door panel off?
- The ABS light is on. I know what ABS is, but the problem is that the brakes seem to work fine. Is the ABS still not working or is something else going on?
Thanks in advance.
Old Dec 20, 2005 | 10:54 PM
waybomb's Avatar
Default RE: Restoration of a 190e
Not sure about your ABS light problem, but I had the same thing on my SL. The OVP relay had a blown fuse on it. The fuse looked good, but when tested with a meter, it was bad. Replaced the fuse and all was back to normal.
Not sure where it is on your car, but I think it is behind the cover behind the battery.
It is a small electronic component, maybe 1.5" x 1.5: x 3" tall. The top may have a clear cover on it. Under that cover is one or two ATO fuses. 10 amp I believe, but I could be wrong.
Old Dec 26, 2005 | 04:50 AM
I replaced the ABS fuse today, fixed the problem. Took me a while to locate it. It was behind the battery as well, and a it was a 10 amp. Thanks for the help.
Andrew
paul.marshall
Aug 8, 2007 06:09 PM
multibenz
Mar 30, 2007 03:01 AM
CedesGirl
Dec 13, 2006 02:21 AM
C280 wizard
Mar 7, 2006 07:15 PM
akboggs
Feb 14, 2006 08:37 AM
