-   -   Resetting maintenance service indicator (https://mercedesforum.com/forum/mercedes-e-class-9/resetting-maintenance-service-indicator-17866/)
dcqme Feb 5, 2007 04:59 PM
Hello all, I am a newbie to this forum, I tried searching for any posting on RESETTING the maintenance service indicator, but came up empty. Maybe I don't know how to search. Anyway, I have a '05 E320, I know quite a bit on maintaining/servicing car. I would like to work on this myself. I was wondering if anyone know how to reset the service indicator. HELP!!! someone. Thanks in advance for your help.
DC :D
Frustration_X_2 Feb 10, 2007 09:06 PM
RE: Resetting maintenance service indicator
late model E320... only way I know to clear it is with code reader... though I would certainly listen to any ideas put forth by the Gurus here, I'm a relative newbie.
paulv Feb 12, 2007 03:54 PM
ORIGINAL: dcqme
DC :D
You can go to http://www.mercedestechstore.com and download the pdf presentations under the W211 section (training files). Get the FSS+ and the W211 Service Sheet. Also, go to http://tech.bentleypublishers.com and select the MB section and look at the W211 area. There are many WIS procedures listed there that a previous member posted for myself and others -- you shoul find all you need to do all your scheduled maint.
Regards,
paul...
Jerks4Fun Jun 8, 2009 08:13 AM
Mercedes E300 resetting Service A Display
Hey PaulV... thanks for the info... it worked for me in Canada like this.
1. put key into possition 1 and press the "R" (reset) button 3 times quickly. Voltage indicator is displayed.
2. use "up" and "down" arrows until you get "Service Data" display.
3. use "+" and "-" to scroll to "Confirmation". and select it using the selection button.
4. turn key to possition 2... the rest is straight forward.
Paul's suggested pdf file is of great help....
http://www.mercedestechstore.com/pdf...2008-16-02.pdf
Thanks...
