Resetting the FSS
RE: Resetting the FSS
Key on (position 2, all idiot lights come on, engine NOT running)
PUSH the trip odometer reset **** twice rapidly, the time/distance remaining for FSS is shown.
PUSH button in and hold it in.
Turn key OFF (DON"T release the button!)
Turn key back to position 2....KEEP holding the button down!
You'll need to hold it down over 10 seconds, you'll hear the beep and 10000 will be the new display. DON'T release the button until you hear the beep, wait at least 15 seconds before deciding on giving up.
make sure your doors are closed , the trip reset is the one that says 0
Ohlord
Ohlord
RE: Resetting the FSS/cjsmith79
try this,
If your car is a 211 variant the other reset is for my w210
1 key on #1 position
2 go to mph display in the cluster
3 press trip odometer **** three times (QUICK) voltage will appear on display
4 Select service menu using + or -
5 Service Indicator Displays Items
6 Press the menu systems button until the MPH display appears
