Replacing rear springs
Hi, I need to replace the rear springs on my 98 E280/210 saloon and i was thinking about doing the job myself. I was wondering if there is anything i need to know before i do this. If any of you have done this job to your merc, how difficult was it. Thanks Paulie. :eek:
RE: Replacing rear springs
Piece of cake as long as you have a spring compressor..... Why are you replacing only the rear springs?
hi mbz, thanks for the reply. ive just changed the front springs and wishbones and the car is sitting up alot higher on the front so i was told to replace the rear springs to balance the car. if you compress the spring does that mean you dont have to touch anything else?
You can also buy different thickness spring pads to fine tune the hieght.....Now you have me second guessing myself. I think if you compress the spring far enough it will just pull right out....If there isnt enough room then you have to remove one of the lower control arm bolts and swing the control arm out of the way to drop out the spring.....Damn i cant rememeber now... Its been awhile since i changed rear springs..
RE: Instrument Cluster
hi i was just wondering if you new anything about repairing the Instrument Cluster on a 01 320cdi. i.e the loss of some of the pixel or digits on the clock and the outside temp. Is it possible to repair yourself????
ORIGINAL: MBZTech You can also buy different thickness spring pads to fine tune the hieght.....Now you have me second guessing myself. I think if you compress the spring far enough it will just pull right out....If there isnt enough room then you have to remove one of the lower control arm bolts and swing the control arm out of the way to drop out the spring.....Damn i cant rememeber now... Its been awhile since i changed rear springs.. an eye/hand on the spring, the LCA bolt holes, and manipulating everything requires care. very simple - just don't rush. the lower control arm technique adds another 30-60 mins depending on type of spring you're installing, your tools and your technique. i found the Klann type (pancake) spring compressor to be key vs the more traditional hook type compressor. use the Force...not force, and you'll be just fine. ;) |
| All times are GMT -5. The time now is 06:46 AM. |
