removing the thermostat
Hi to all,
Let's say that the car is overheating and the thermostat could be the cause but far away from my garage and cannot replace it right away..........
What could happen if I remove the thermostat and drive without it?
thank-you
thank-you
once located a store for the new t-stat, I did remove the old one just to try my teory, and you were right it took 3 min. and the car was over 100.
I installed the new one and the running Temp went back to "normal", or at least what I thought it was supposed to be "normal", infact while I was waiting for the New T-stat I started to look at the Fan clutch.........Interesting part this one.....I definetely think that mine is on it's way south infact when engine is cold I can move it with some resistance but the same little resistance is present when the engine in hot.
maybe i am again wrong ,but i dont think it should be that way.....
Thank-you for your reponse.....
pseverin
Aug 31, 2010 01:54 AM
nandrolone
Nov 9, 2005 01:14 AM
benz, bypass, diesel, engine, forumremoving, gioffre, happen, hose, mercedes, mercurio, performance, remove, termostat, thermostat, youtube
